EVO No Limits Swaybar Disconnect
Old Feb 21, 2012 | 09:46 AM
Desert Fox's Avatar
Veteran: Navy
Cool EVO No Limits Swaybar Disconnect
I just reviewed the search engine for the subject part and found nothing that addresses these questions:
- When you disconnect the e-sway-bar electrical junction box, you can't just leave it open. Do you fill it with silicone foam or what? What keeps it dry when you are running in 18" of water?
- Part 2: The electrical connector, that you just disconnected from the junction box, is zip tied to the "cross member." How do you keep it dry?
- In the EVO instructions that came with part do not mention turning off or disabling the e-sway-bar system once you have installed the manual part. Shouldn't that be done? How do you turn off the blinking dash light?
Any assistance would be appreciated.
Old Feb 21, 2012 | 09:55 AM
Biginboca's Avatar
I am only familiar with the system from reading about it, but why would you disconnect the electrics? It seems that if you left it connected the lights would function as normal and give you an accurate indicator of swaybar connected and disconnected, which could be handy, no?
Old Feb 21, 2012 | 10:07 AM
rinkishJK's Avatar
I believe u remove the motor from the bar and replace it with the evo piece.u then need to wrap the plug end up, and tuck it away. U will need a dealer to turn off the light with the scan tool. Give them a call and Im sure they can answer u better.
