Evo suspension question.
Old Dec 12, 2011 | 07:26 PM
Whytiptoe's Avatar
Hello I am looking into the evo double throwdown kit and I am confused by something. It stats that is has 14" of vertical travel. Could someone explain that to me a little more as I would think the system would travel more.
Old Dec 13, 2011 | 05:40 AM
wayoflife's Avatar
JK-Forum Founder
it means the shocks will allow for 14" of travel. in other words, the amount your axles can articulate when flexing on the trail is a lot!
Old Dec 13, 2011 | 08:12 AM
Andrew@EVOMFG's Avatar
Sponsoring Manufacturer
EVO MFG Representative
The EVO DTD systems give 14" of vertical wheel travel. Most standard coil and spring lift kits yeild around 8"-9" of usable vertical wheel travel. Therefore 60%-75% improvement over a standard lift kit.
EVO
Old Dec 13, 2011 | 02:13 PM
Whytiptoe's Avatar
Thanks for the info.
Old Dec 13, 2011 | 02:14 PM
Whytiptoe's Avatar
EVO
Old Dec 28, 2011 | 06:18 AM
clarsen's Avatar
EVO
Andrew how's it going hope your holidays went well. I bought Mels 40" tires and I am trying to mount them but I am getting rubbing on the frame in front and will have to do some cutting in the rear. My question is can I adjust the ride hieght enough to allow me to run the 40's? with my 12" front coils. Is there a diference with the EVOlever between the 12 and 14 systems? Have you guys put 40"s under a rig with my setup I still have the D44 and will run wheel spacers? Thanks
Whytiptoe EVO DTD will not let you down and the travel you will get is nothing less than amazing.
Chris
