EVO1 Race JK suspension ?
What does this JK have in common with EVO1?
Both of these JK's are running our Off the shelf production Double Throw down systems! EVO1 needed a motor that could go fast and keep up to the suspension! The cage work is for saftey of the driver and required for racing in the Unlimited class at KOH.
EV01 will be running off the shelf Dynatrac Prorock 60 and 80 in the rear, along with EVO Spec King shocks.
Cool! I apologize for what may be a dumb question, but I just started researching your suspensions last week because I am interested in your coil over system. In addition to the double throw down, is the black JK running coil overs? From the pics it doesn't look that way...
heres the suspension both Jeeps are running
http://www.offroadevolution.com/stor...UBLEDOWN-FRONT
http://www.offroadevolution.com/stor...OUBLEDOWN-REAR
http://www.offroadevolution.com/stor...ONGARM-UPGRADE
Double throw down is coilovers with bypass shocks
EVO: Suspension / Steering, Front Double ThrowDown System
EVO: Suspension / Steering, Rear Double ThrowDown System
EVO: Suspension / Steering, Extreme High Clearance Long Arm Upgrade Kit
Do many guys run the coilovers in the front and normal springs and shocks in the rear? Seems like the coilovers in the front would still smooth out the ride on bumpy surfaces while traveling at speed.
unreal...I wish i could stomach $10k for that suspension + probably $1k install cost...
And you install cost is probably a little more then $1k for the DTD and long arm system.
