Exhaust Extension?
Just recently purchased a Teraflex BB lift. I have seen some companies say that it is recommended that you get a exhaust extension tube. Any suggestions or recommendations on this?
If your jeep is a 2012 up the exhaust spacers are the cheaper route to keep your driveshaft from hitting the exhaust crossover pipe.
That's what I have on mine for now with the teraflex 2.5" BB
That is usually only needed for 2012+ models with a lift height of 3" or more. I recommend installing the lift and seeing if your driveshaft clears the exhaust. If there is no rubbing on the exhaust, then you won't need the spacer. I'm running a 2" BB on my 2012 and haven't noticed a need for the spacers yet. So, I'm assuming you'll be fine as well.
Hope this helps. Let me know if there's anything else I can help you with.
-Zach
i used to run the teraflex exhaust spacers. i took them out when i added my dynomax exhaust because the tail pipe would stick out too far. i have them sitting in my room with out the hardware if your intrested just pm me.
