Exhaust mod questions
Old Jul 30, 2009 | 06:03 AM
jkkat's Avatar
good luck with the combo of K&N filter, cat back exhaust by local shop with Turbo muffler and straight out tail pipe of and of course with the 5:13 gears and 35's with a 6 speed, I can almost take a ricer.
Old Jul 30, 2009 | 06:14 AM
JPop's Avatar
Originally Posted by BryGuy
The one thing that I've noticed in regards to JK's, both in parts and discussion on the forum, is that when it comes to engine performance mod's they only really address 2 stages of a 4 stroke engine...... Intake & Exhaust. The Compression & Combustion stages are all but ignored..... But there really isn't any options, as far as I know (beyond what the Flashpaq does).
Yep, very limited in what you can do. As OBX pointed out, a major issue is the Y pipe and secondarily the throttle body. I would think at some point some brave soul will have a Borla long tube installation with added cats and I'd also suspect someone like Hesco will introduce a replacement throttle body. Both of those things are going to require some intervention on the PCM side, such as a throttle body relearn as Superchips has on other platforms, and likely an actual tuner to cope with the long tubes.
Myself, I've already resigned myself to the fact that I will be purchasing a Pentastar equipped JK as soon as one becomes available and for the foreseeable future a performance mod that comes for the 3.8 JK motor will need to be as much of a no brainer as the Flashpaq was.
Old Jul 30, 2009 | 06:18 AM
OBX_JK's Avatar
Originally Posted by JPop
As for the after market cats, I looked at, perhaps it was really just dreaming of what ifs and I don't think they would be that hard to make fit and weld in. The bigger problem is no tuners for the platform, probably won't ever be and your maxed out with what can be delivered with a programmer. Additionally with the tuners that are on other chrysler platforms none of them seem to have the chrysler PCM dialed in as well as superchips. While they can be helpful when people really push the limits of their engines on these other vehicles, I continue to see lots of comments from users of Diablo or SCT make mention of "when they get XXXXX figured out like Superchips".
Superchips will never have full tuning capabilities. Their isn't a demand for it. Plus the fact that their are too many idiots who will blow up their engines because they don't know what they're doing, and then get mad at Superchips.
Anyway, you're way more savvy on the tuner stuff than myself and the long tubes with cats aren't something that I plan on being the guinea pig for.
My next mod will be a test pipe, no cats
bostonMA's Avatar
Avoid a duel 2.5" exit system (i.e. gibson). It will be loud but you will feel it having to rev harder to get going.
Old Jul 30, 2009 | 06:24 AM
OBX_JK's Avatar
Originally Posted by Phishjeep
No, not a flowmaster 40 if you don't want it loud. Chambered mufflers are loud and they drone. Stick with a straight thru design, like the magnaflows or several others. And I'm pretty sure deleting the cats is illegal everywhere in the US.
deleting cats is not illegal everywhere. i have done tests and have quantifiable data that shows real gains with a flowmaster 40 over other mufflers. if it's about sound, go with something else.
Old Jul 30, 2009 | 06:27 AM
JPop's Avatar
The reason Superchips won't having tuning capabilities is because their parent company has placed CARB requirements on them.
As far as blowing stuff up, when some transmission stuff becomes available as on other platforms and because it doesn't have emissions issues, there will be plenty of shiznit blowd up.
Old Jul 30, 2009 | 10:39 AM
mbanik's Avatar
Default MBRP opinion
I installed the MBRP cat back about a month ago on my 2dr 6 spd. The dyno sheet looks good, but I wish I could have dyno'd before and after myself. Since they are one of the few companies that actually publishes an application specific dyno sheet I felt OK about it, definitely don't believe the exhausts with the "up to 30 horsepower" claims... garbage, probably more in line with the MBRP gains.
The torque/power improvement is not noticeable on my butt dyno. It may be a bit more snappier but that might be psychological. Gas mileage bumped up 1.5-2 mpg on highway long hauls ... no improvement noted on the around town gas mileage.
Sound wise it growls and gurgles when idling and crawling. It can be loud when you boot it but it's quiet around the neighborhood when you are easy on the gas. Seems a little buzzy at times ... not high toned buzz like a 4 cylinder, but also doesn't sound anything like a decent 6 cylinder or 8 cylinder. Think mid-range.
I like it ... if I did it again I'd probably go with muffler relocating version.
-matt
Old Jul 30, 2009 | 01:28 PM
syndicate559's Avatar
Yes, their is. Changing the muffler only, will just change the exhaust note. Their are more restrictions and issues before the muffler that need to be dealt with. I don't understand how you think their isn't much difference between a full cat back system and just swapping out the muffler.
Look at it like this: If flow velocity increases right after the cat, it will have increased 9 ft before the exit. If flow velocity increases right before the muffler it will have increased right before the last 18 inches. Which do you think would be more efficient?
Without going and crawling under my Jeep right now (it's 100 degrees outside and I'm pretty sure I don't want to lay on the driveway), I'll ask this question: There's nothing between the factory cat and the muffler but pipe, right? If so, you're saying that aftermarket pipe is going to give me considerably more flow/velocity than the stock pipe?
I could totally be missing something, though. Anyway, thanks all you guys for your input. I think I'll stop into a few muffler shops as I'm out and about to talk about options. I don't have any real knowledge of where the MBRP kit relocates everything to, so if you were me walking into a muffler shop and asking about relocation, what would you tell them you want specifically?
Old Jul 30, 2009 | 01:52 PM
JPop's Avatar
The reference was to the Y pipe which includes the cats. The thing does suck ass, is way expensive if you damage it and an easy target for a performance boost if you think you can master the PCM.
Old Jul 30, 2009 | 01:56 PM
cbrewer22's Avatar
i have a full flowmaster cat back and its really all sound u will get like 1more hp and i noticed a little better mpg.
