Exhaust spacer with leveling kit?
Old Jan 17, 2015 | 02:19 PM
anviljk's Avatar
Default Exhaust spacer with leveling kit?
Im leaning towards the EVO leveling kit (2" coils front, 3/4" spacer rear). Will I need anything else like the exhaust spacer, extended brake lines/sway bar links?
Old Jan 17, 2015 | 02:42 PM
landsharkjs's Avatar
No , should be fine .im running terraflex 2"front and 1" rear spacers and no issues on 2013 JKU
Old Jan 17, 2015 | 02:55 PM
TheNoob's Avatar
Are you changing your shocks? I have a TF 2.5" BB with shock extensions and mine doesn't contact the exhaust at full droop. If you go with longer travel shocks you might need the spacer. Only way to find out for sure is flex it and see.
Old Jan 17, 2015 | 04:27 PM
anviljk's Avatar
Is that all you're running? Any driving/handling issues?
Stock shocks without extensions.
Old Jan 17, 2015 | 06:37 PM
TheNoob's Avatar
You won't need the spacer. Stock shocks don't allow enough flex for the driveshaft to interfere.
Old Jan 17, 2015 | 06:44 PM
muddyman184's Avatar
I run TF leveling kit no exhaust spacer never hit offroad and drives on road like factory felt no difference before/after the lift and I have the coil spacers
Old Jan 17, 2015 | 07:02 PM
anviljk's Avatar
Thats good news. What about the stock sway bar links?
No flightly feeling on the road? Any issues at full flex with it disconnected?
Old Jan 19, 2015 | 09:07 AM
Nope no flighty feeling and my 33s rub the factory air damn when turning in full stuff I can remove it or trim but not going to lie I'm lazy. Other then that I've had no issues.
Old Jan 19, 2015 | 11:56 AM
Lefty14's Avatar
I have the TF leveling kit on my 2012 Sahara. The kit came with longer sway bar links in it. You should have them also.
Old Jan 19, 2015 | 01:07 PM
notnalc68's Avatar
I don't think so. There's a sticky in modified tech that covers that.
