Exhaust spacers?
Old Feb 24, 2015 | 12:14 PM
beezler11's Avatar
Default Exhaust spacers?
Have a 4 inch rough country lift and 35s. Heard some problems with the exhaust coming in contact with the cv boot and front driveshaft. Are exhaust spacers worth it? If so, any brands to avoid or are they all pretty much the same?
Old Feb 24, 2015 | 12:18 PM
elitecontrol's Avatar
you need either the spacers, y-pipe or after market driveshaft.
i installed the teraflex before. didnt like it. rattled bad.
i also installed a synergy before. worked perfect. if you decide to go this route. totally recommend synergy.
Old Feb 24, 2015 | 03:03 PM
TheNoob's Avatar
I have the teraflex exhaust spacers and have no problems with them. I went with these over the cheaper ones just because they are cylinders and won't disrupt exhaust flow. Not that I've ever heard of a problem with the cheaper ones..
Old Feb 24, 2015 | 03:20 PM
mds22's Avatar
I have brand new, still in the plastic Synergy exhaust extension/spacers if you are interested pm me
Old Feb 24, 2015 | 05:04 PM
dalearyous's Avatar
rancho makes a piece of exhaust that is cheap, better than exhaust spacers, but i will warn you it sits low under the belly of the jeep. found here. i am currently running it and have had zero issues with it and haven't banged or smashed it. just another cheap option until you have to replace the front DS.
