Exhaust Upgrade
I know you said not too loud, but I have mine chopped off and I like it pretty well. The farther back you cut, the 'quieter' it gets. Mine is cut below the driver's seat, but I bet if you did it behind the rear axle it wouldn't be too bad. Relatively free and easy mod. Makes highway driving a little better, too. Otherwise, I would say throw a Flowmaster on it or the like.
I'm about to modify my Dynomax Rock Crawler exhaust because my new lift is causing rubbing on the rear track bar and sway bar. I was planning on removing the entire rear pipe that extends from the muffler (which sits under the middle of the Jeep) and throw on a turn down pipe. Will this make it quieter? I was assuming it would get louder.
yes you did thanks! You also said to check the local auto stores which I did and I can get a very cheap turn down tip if I don't want stainless. I was going to pick one up (they are around $8 or so) just to give it a try. Not sure on size yet but I think it would be 2 1/2" that I would need, right?
Also reuse the same clamp.And got your PM too.
I've been enjoying the corsa db, sounds good, not loud, has a cool gurgle. Tucks up higher than stock and is lighter too. Some drone in the cabin at lower speeds but not do much at highway speeds.
