exploded t-cases ?????
The cases that I've seen fail have all been rubicon cases, that said I believe that the case half's for the 3.21 and the 4:1 are the same. It is just the internal gearing that is different.
There has been a lot of debate about a different DS design that doesn't use the double Cardon joint. Most on the forum believe the double Cardon is the better joint. To be honest I really don't know the technology about the difference between the 2 joints. I know of no TC failures with the new DS design, but then again I don't know of anyone who is actually running with it. I have also not heard of anyone running it for a long enough time to profess that it's better and that it will solve TC failures.
The aftermarket driveshafts are what is causing the problem. The extra mass of the aftermarket cv joint is bad news. There is a new style that can handle more angle than the old style and it is less massive. I don't recall the name of it but that is the one I would want to have if I were going to change mine.
aftermarket drive shafts ARE NOT what are causing the problem - vibrations are and most of these are caused by too much caster on a jeep that's running 5.13 gears or higher. fancy joints or less massive drive shafts are NOT what is needed to address vibrations - making sure that you have the proper caster set and that your drive shaft is well balanced is.
the only bad news here is hearing guys like you come on this forum with terrible and uneductated information like this and as if you were actually some kind of authority on the matter
Yes, I agree, vibrations are causing this. So you can tell all of us that the combination of low gearing with an aftermarket driveshaft, and bad driveline angle is not causing this? So lets play a little deductive reasoning game here. There are many more folks running lifts with aweful castor specs and are geared low running a stock driveshaft than those running this same set up with an aftermarket ds.
https://www.jk-forum.com/forums/show...-case-exploded
Not ONE has blown up a t case with a stock shaft on.
https://www.jk-forum.com/forums/show...-popping-sound
make no mistake, once the joint seizes up, bad things would happen. of course, if you spent less time reading things on the internet and more time working on jeeps and or wheeling them, you would know this.
The two of you have said the same thing, using different points of reference.
LOL!! just to be fair, he's saying the same thing as me - just using a different point of reference. still, too much caster or, as he liked to put it, a "bad driveline angle" is a problem with install error and NOT a problem with the type of drive shaft used.
That is true.
