Extended breather lines for Snorkel ?
Old Mar 13, 2014 | 04:55 PM
chevyok06's Avatar
Default Extended breather lines for Snorkel ?
Ok so i know it's been brought yp and i know there are a million threads but no one has a definitive list of exactly what i need to buy to do the install. I am looking for inner diameter and length of what hoses and correct size and number of fittings . THANKS For the help. I have a 2011 jku sport. 3.8 auto. THANKS
Old Mar 13, 2014 | 05:13 PM
chevyok06's Avatar
Never mind. Ordering the smiling bob kit as we speak. Just hope it works ok with my 3" Lift. Thanks any ways.
Old Mar 13, 2014 | 06:25 PM
RevyJKU08's Avatar
5/16 fuel line - cant remember how much again maybe 25'. Hose clamps to clamp hose on diff/ transmission & transfer case nipples. And couple zip ties to snug up the slack. Just reuse stock breather tube top caps!
Old Mar 13, 2014 | 10:01 PM
chevyok06's Avatar
In hooking them into my breather box so the basically use my snorkel for air
Sent from my HTC One using Tapatalk
Old Mar 13, 2014 | 10:17 PM
brutalvette's Avatar
I don't know for sure but putting the breather tunes into the intake seems like a bad idea to me. I would double check this.
Old Mar 14, 2014 | 03:08 AM
Mark Doiron's Avatar
Originally Posted by chevyok06
Ok so i know it's been brought yp and i know there are a million threads but no one has a definitive list of exactly what i need to buy to do the install. ...
I do. And, unless the kit you bought has been modified, I have an improvement over it for the Pentastar motors (replace one T-connector with a Y-connector for the air intake to make your hose routing much easier if you have a '12 or later--pick up the Y-connector at Lowe's in the underground sprinkler parts section). If anyone is interested in the full parts list, provide me an e-mail address and I will send it to you (I don't want to appear to be competing with Smilin' Bob on the forum, LOL).
Old Mar 14, 2014 | 03:16 AM
If you overfill the differentials (easy to do if you fill up to the fill port on aftermarket diffy covers), then you could end up dumping diffy oil into the engine intake. So extend the breather lines to the air intake, don't overfill the diffys, and you'll be protected for deep water runs ...
Name:	Buckhorn OHV Trails, Jan 14, 7_3489, Brandy River Crossing (Mark's Jeep).jpg
Old Mar 14, 2014 | 01:47 PM
Is there still any risk of pulling oil vapors into the intake?
Old Mar 15, 2014 | 01:06 AM
Well, I suppose about the same as pulling oil vapors from the crankcase into the intake (that is, after all, what the PCV valve does).
Old Mar 15, 2014 | 01:33 AM
K9wells's Avatar
I installed the river raider cast snorkel with there universal aftermarket airbox and run all breather hoses to it the only thing is, is if i change any fluids ill take the hose off for and take it for a long drive than connect the hose back to the breather airbox.
