extra travel from disco's
Not sure about exactly how much more you get but wow what a difference. Like night and day. Pretty scary on the road though. I had one break and i just left it until i tried to dodge a moose. Now i'm just saving for the disco's
How much longer shocks did you put in? Watch your brake lines because generally without straps your shocks become your limiters ...
If I were you I would jack it up and drop the wheel as far as possible to:
1) Make sure your brake line is safe
2) Make sure your spring doesn't fall out due to the longer shocks.
True about the rubicon, but he said he added long travel shocks. Dmhines is pointing out how the stock shocks bottom out before the brake lines stressed. With the extended travel shocks it may be able to droop enough for all the bad things mentioned above.
How much extra travel will I get if i have sway bar discos? I am running a 2 inch spacer in the front with long travel shocks.
Disconnected, with 4" of lift and 2" bumpstops, I still rub my 34's on the upper fenders.
