Or-Fab Carrier install trouble
Have any of you had trouble/issues with your carrier install. Could you give me an estimate on the length of the female extension that holds the tire...mine is way too short to extend thru the center of the spare of even engage the threaded end of the tbar.
Both yhudson with Or Fab and David @ Northridge have both responded today to the fit issue/questions and some major powdercoating finish problems with the tire carrier I received yesterday. Big kudos to Or Fab and Northridge4x4. They are going to correct / fix the problems. Thanks guys!
Just saw this on the online manual I'm using for installing mine:
NOTE
These carriers are designed to carry an aftermarket
tire/wheel. To carry a stock tire/wheel, you need the
optional Bolt Plate Adapter, Kit # 87012.
NOTE
If you click on the buy now tab the picture of the item appears... I'm thinking about changing the T handle out for one of these.
