Fab Four Diff cover Issue
Old Dec 17, 2008 | 07:53 AM
Munday's Avatar
Default Fab Four Diff cover Issue
Who out there is running Fab Four diff covers front/back ? I'm having clearance issues on with the rear track bar hitting the rear diff cover. I'm also running the 4.5 RE lift if that makes any difference. I have not seen the issue my self as I had to get a local shop to install it as I once again had to go back to work . I will be back to take a look at it tonight.Any info would be grate.
Thank you.
Old Dec 17, 2008 | 03:45 PM
Munday's Avatar
Nobody has had this problem?
I guess I could buy an aftermarket track bar that has more bend but I would like to know what is going to work before I buy something. What options are out there??? I'm getting sick of it when I buy things and they don't work out .....
Old Dec 17, 2008 | 04:06 PM
wayoflife's Avatar
JK-Forum Founder
is it hitting a lot or just a little? could be that you just have the main control arm set too long. if you can, try shortening it up a bit. that might do the trick. of course, if you have an aftermarket drive shaft, you will need to remember to adjust the upper radius arm links as well to keep things in line.
