FabTech
Old Feb 20, 2008 | 08:11 AM
rolly's Avatar
Originally Posted by JKTyrant
Man I had no problems with the TeraFlex BB and its a hell of a lot cheaper for a spacer lift then the Fabtech . Man for only about 30 dollars more you could get the FT 3" Econo lift with the M-Force Monotube Shocks and its a Coil Spring lift not a space lift. That is what I did and I love it
WHAT'S THE DIFFERENCE BETWEEN COIL SPRING LIFT AND A SPACE LIFT ???
Old Feb 20, 2008 | 08:16 AM
BLKRUBI's Avatar
Well, simply put, a coil spring lift gives it's lift from longer than stock coil springs while a spacer lift are just that, spacers that sit on top of the factory springs to give you lift.
Old Feb 20, 2008 | 08:19 AM
JKTyrant's Avatar
Coil spring lifts, will lift the jeep using a longer more Heavy Duty coil spring, spacer lifts just put a spacer in between the stock coil spring and the coil spring seat. Coil spring lift is the way to go.
Old Feb 20, 2008 | 09:30 AM
tgrt's Avatar
Former Vendor
Originally Posted by directedby
I am very happy - this kit is much more than spacers - It has no Alignment issues, no driveshaft issues and has much more than the Tereflex kit (which so many users are having problems with).
•*Proper front-end alignment is insured with this system due to the •*included adjustable alignment cams.
•*Also included is a front driveshaft boot clamp kit to allow additional clearance between the front driveshaft and transmission during full suspension articulation.
You lost my interest in the kit when the word "cams" came up.
