Fabtech lift?
5" is A LOT of lift and not one i would recommend unless you were planning on running 37" tires or bigger and certainly, not as a short arm kit. IF you get this kit, make sure to have the track bar relocation brackets welded up with extra gussets as i have seen more than enough tear off the factory mounts right off the axle and cause all kinds of death wobble.
