Factory Rake LOOK is back
Old Mar 1, 2011 | 06:36 AM
JKPhoto's Avatar
Default Factory Rake LOOK is back
I added a TF leveling kit a few months ago. Then this past weekend I added an AEV Front Bumper and winch to my JK. The added weight has brought the Rake look back. Any suggestions on what I might do to level it back out?
Old Mar 1, 2011 | 06:37 AM
wazooz2424's Avatar
switch to the coil leveling kit or add bigger/more front spacers. front spacers can be stacked, rears cant. the factory coils will eventually sag from the added weight.
dj1123's Avatar
Puck the front.
Old Mar 1, 2011 | 06:40 AM
Merlin4979's Avatar
Get a heavy rear bumper.
Old Mar 1, 2011 | 06:42 AM
Biginboca's Avatar
Yep, just needs some junk in the trunk, lol!
Old Mar 1, 2011 | 07:20 AM
HG07JKRubi's Avatar
new HD coils ...
Old Mar 1, 2011 | 07:41 AM
largo's Avatar
Switch to a 2.5 coil and shock lift, and it will solve your problems. I used the Teraflex kit, and added a 1" spacer as well on the front, to accomodate the Warn 9.5ti winch. It worked great. Comparatively priced, and I did not sacrifice any handling or ride qualities. I only run 33's however.
Old Mar 1, 2011 | 07:48 AM
Jeepin Dad's Avatar
Take a look at the part # of your front springs, you may be able to find some stiffer factory takeoffs for cheap.
Here is the results of my swap, I picked up the springs from one of the local 4x4 shops for $45.
https://www.jk-forum.com/forums/show...to-my-2-door-X
Old Mar 1, 2011 | 08:47 AM
mbfrosch's Avatar
I guess it's just a preference thing for the rake, I do not even notice it that much.
Old Mar 1, 2011 | 09:14 AM
JKPhoto's Avatar
What if I add the TeraFlex 2.5" Budget Boost with Shocks. Will that remove the rake or only lift what I have with the rake still noticeable? I'm actually happy with the hight of the rear. Only need the front to match. Tape measure says its about .75 inch off.
