Factory Rubicon Sway Bar Question
Old Apr 12, 2011 | 09:02 AM
BKGM Jeepers's Avatar
Default Factory Rubicon Sway Bar Question
Not sure where to put this thread.
I have an 08 Rubicon JKU. I am sick of the swaybar reconnecting whenever I cross 18 mph.
Does a programmer exist that can allow me to discconnect and reconnect the sway bar whenever I want?
I believe bullydog offers one that auto reconnects on and off at 35mph.
My superchip programmer does nothing, according to my manual.
Any ideas or suggestions?
Old Apr 12, 2011 | 09:06 AM
shockwaveaz's Avatar
Why do you need the increased articulaton over 18 mph?
Sounds like you just like roller coaster rides. This could be dangerous but I there is a write up out there how to do an override just like the lockers.
Old Apr 12, 2011 | 09:38 AM
4-hi in snow off road my most common example. Running longer mud holes is another where you need momentum.
I'll need to check out the overide. That's a good lead - thanks!
I forgot to mention that hitting deep ruts while driving with it connected has bent the links.
Old Apr 12, 2011 | 10:35 AM
ronjenx's Avatar
I, too, have found the 18 mph reconnect annoying, because it sometimes takes a while for it to disconnect again, depending on the terrain.
Old Apr 12, 2011 | 10:44 AM
cyberfalco's Avatar
The BullyDog GT Gas Tuner changes it to 30MPH.
w ww.bullydog.com/documents/Special%20Edition%20Jeep%203.8L%20JK%20-%20GT%20Gas%20product%20info%20sheet.pdf
Old Apr 12, 2011 | 10:52 AM
Castalone's Avatar
I just got the jks quick discos. I like to have them disconnected all the time for desert stuff, even in 2 wheel drive, much better ride and more speed through rough stuff. Also I over extended mine with the rubi swaybar disconnected and bent stuff.
Old Apr 12, 2011 | 01:00 PM
I was on a run 2 weeks ago and a guy from my group had his rubi swaybar reconnect and bend one of his links. That's what I want to avoid.
Also, why suffer a punishing ride when you don't have too!
The bully dog 30 mph correction is appreciated as well.
