fan not running
Old May 17, 2013 | 06:10 PM
HighTide's Avatar
Default fan not running
OK... I am not new to the game. My 07 JK is pushing 100K.
But, today, after idling with the air on for about 10 mins, my ABS light came on and
the s.o.b. drove like the steering wheel was off center. . . no power, acting like it was cutting out... ect.
So I got home, and noticed the fan was not running! it ALWAYS runs when idling with air.
So that seems to be root of the problem... 1st things 1st.
but is it the fan, or relay? and how can I tell?
Old May 17, 2013 | 06:21 PM
ilikeguns's Avatar
hmm.. you throwing any codes? You can check by doing this..
Project-JK.com - Jeep JK Wrangler Resource » Jeep JK Wrangler Diagnostic Trouble Codes DTC How to Check Them
Old May 17, 2013 | 07:00 PM
orangedude71's Avatar
Have you doused it in mud lately? Search the forums for posts about mud getting into the vents on back of fan motor
Old May 18, 2013 | 09:22 AM
HighTide's Avatar
My clock spring is bad so I am sure I would get a butt load of codes!
No mud for about 8 months.
Old Aug 19, 2013 | 11:25 AM
4WHLN's Avatar
Any new info on this? I am having a ac fan issue also and trying to figure out what is the problem
Old Aug 19, 2013 | 12:34 PM
LOST's Avatar
This might be a long shot but how old is your battery?
My 07 went haywire when the factory battery started going out.
Wipers would come on, windows would randomly roll down, dash would go black at night.
Freaky. wasn't sure if I should call a mechanic or an exorcist.
Deep cycle Odyssey drove the demons away. Been fine ever since.
Old Aug 19, 2013 | 03:25 PM
Smashboogie 4x4's Avatar
Former Vendor
1st place to check is your fuses. They have a 60amp maxi fuse that tends to pop when the fan gets filled up with mud. I carry a spare.
Old Aug 25, 2013 | 06:32 PM
DeucesALLin's Avatar
Default ^^^n3ver heard this
I am on my 3rd fan...in 120k miles of abuse. if fans not working, hit it. It will get you home. Then go to advanced and get a $135 lifetime replacement fan and wire in a 60amp relay and kill switch.
