Feels like the tire is bouncing in the wheel well.
I had the same issue. The bolt holes that secure the front track bar on both ends became elongated due to bolts becoming loose. I had to have a heavy duty washer welded onto both sides of each of the mounting brackets to fix this issue. After this fix, I still had a slight wobble from time to time. I then checked all of my bolts for the upper and lower control arms on the front and rear and found two bolts on the front control arms loose. I then tightened all control arm and track bar bolts both front and back. This cured my death wobble. I also noticed my steering damper is shot. Will replace it with after market one soon.
