Fender flares
Old Apr 27, 2013 | 01:15 PM
Flexer07's Avatar
Default Fender flares
I would like to see some pictures of fender flares and suggestions.
Old Apr 27, 2013 | 01:16 PM
kh202's Avatar
Cut yours for free
Old Apr 27, 2013 | 07:00 PM
Ryan0260's Avatar
Originally Posted by kh202
Cut yours for free
X2. Free and and looks good.
Old Apr 27, 2013 | 07:03 PM
Flexer07's Avatar
What do you do for the ruff edges after you cut them and what do you use to cut them
Old Apr 27, 2013 | 07:37 PM
Quentin_T's Avatar
Used a dremel to cut mine, and a knife to cut off the excess, trimmed with door trim. Check out the write up.
Old Apr 27, 2013 | 07:41 PM
matprovo's Avatar
File and sand them down. Then you can put door edge trim on the edges to give it a cleaner look. I cut mine with a saw zall.
ID:	451857   Click image for larger version
ID:	451858   Click image for larger version
ID:	451859   Click image for larger version
Old Apr 27, 2013 | 08:44 PM
catahoula's Avatar
Yes trim them! I picked up a free set from a member to do just that. Way cheaper than aftermarket where you will spend @ $500 and up.
951JEEP's Avatar
CUT EM!! Used a dremel with plastic cutting wheel from start to finish. Cleaned up the edges with my orbital sander and used door trim to finish em up.
Old Apr 27, 2013 | 09:25 PM
tnt008's Avatar
Cut yours for free
I heard they flap on the highway. With that said, I was thinking about doing it, then bedlining them. Any thoughts on that???
Old Apr 27, 2013 | 09:51 PM
catahoula's Avatar
I would keep the fender supports and trim as well. That should help with the flapping. I've not read of anybody having that. As for bedlining, I myself would just keep it the same...I'm also cheap too!
Sent while sitting in my Jeep using JK-Forum
