Fender Flares
Old Aug 16, 2008 | 06:21 AM
husker_shoe's Avatar
If you like the Xenons go for it, but after seeing them up close, I don't really like them. No offense to anyone with them, but the fronts look ok and the rears are just hideous IMO. Definitely try to catch some installed up close first
Old Aug 16, 2008 | 07:20 AM
serveapurpose's Avatar
Sponsoring Vendor
Off Road Evolution Rep
The stock fenders pop loose way to easy! I installed a 1 inch body lift and no more rubbing, which means no more popping off. Even though I plan on buying tube fenders from a non-sponsor eventually. Good luck
Old Aug 16, 2008 | 11:23 AM
aldaman's Avatar
Originally Posted by JTLJCox
...... was just wondering about my options here? I would really like to keep the suspension stock if possible, but obviously want to also keep the 33 inch tires and have coverage to be legal on the road here in Maine.
Originally Posted by SASQUATCH
......Flatties will ABSOLUTELY give you at least 2" more clearance in the back full flex.
Originally Posted by serveapurpose
..... I installed a 1 inch body lift and no more rubbing, which means no more popping off.
x3 - If your looking to keep your suspension stock and run 33s with no clearance issues...Go for the 1" BL (I've heard the BL will also yield another 2") and flat / tube fenders
Old Aug 16, 2008 | 11:44 AM
TxCop07's Avatar
Vet Army
get the 2" BDS BL
Old Aug 17, 2008 | 07:32 AM
JTLJCox's Avatar
Wow, pretty strong consensus toward the body lift. Thanks for the input. I was always leary of them as my early memories of pickups with bodylifts remind me of the following:
Extremely short transfer case and transmisson shifters, do you see problems with a 1 to 2 inch BL in an auto?
Very obvious frame rails signifiying you were body lifted
I always heard they were a lot of work to install as you had to basically disconnect the chassis from the frame. Is it easier in a jeep? Am I wrong to assume a BB is easier to install than a BL?
The group pretty much has me sold on the Xenons, however. You never know, maybe that will be the answer on it's own.
Great site, great insight. Thanks all.
Old Aug 17, 2008 | 07:45 AM
dyolfknip's Avatar
Check it out yourself:
http://project-jk.com/jeep-jk-write-...ation-write-up
WOL did one to his.
