Finally lifting the JKU. Quick Question
Old Apr 10, 2014 | 05:22 PM
mbpike's Avatar
Default Finally lifting the JKU. Quick Question
So I called the great people at Northridge today. Got set up with 2.5" Mod Stock system with Bilstein 5100, Teraflex bump stocks, and the grade 8 bolt kit. I'm going to order my extended brake lines first thing in the morning.
Soooo my questions is, Do I need anything else to do this lift? Any suggestions of anything that might compliment this kit?
Old Apr 10, 2014 | 05:52 PM
Doschmafia's Avatar
New wheels and tires !!!! If you don't have some already picked out that is.
Old Apr 10, 2014 | 05:59 PM
mbpike's Avatar
Just put on 17" Fuel Kranks and 285/70/17 nitto trail grapplers last week.
Old Apr 10, 2014 | 06:03 PM
suicideking's Avatar
Is it the RK stock mod lift? A good addition would be the lower control arms. Or even just the front lowers depending on your budget.
Drive it a bit fist. If you're happy with the way it drives, add something else. Front bumper?
Old Apr 10, 2014 | 06:21 PM
mbpike's Avatar
Originally Posted by suicideking
Is it the RK stock mod lift? A good addition would be the lower control arms. Or even just the front lowers depending on your budget. Drive it a bit fist. If you're happy with the way it drives, add something else. Front bumper?
It is the stock mod lift. The plan was to add the control arms as I go or as needed. I'll deff. drive it to see how it does. The bumpers will come after a while, I'm thinking JCR front and rears and then some rock rails
Old Apr 10, 2014 | 08:01 PM
If you're going to wheel it, you will need the rails first. Skids and diff covers are also a good investment.
Old Apr 10, 2014 | 10:22 PM
Roryslife's Avatar
Rails immediately.
Skids soon.
Diff cover, when you can afford it.
