Finger control for the throttle?
Old Mar 26, 2011 | 09:21 AM
GON WHLN's Avatar
Default Finger control for the throttle?
Another post got me thinking....
We used to have a 95 YJ and installed a TF finger control for the throttle. It went from the throttle body through the firewall to the stick. Made for slow crawling without having to the use gas or clutch.
I was wondering if anyone has modified this for the JK TB? It would be great to use for idle winching or OBA's or crawling.
Hope I'm not being stupid here... yes/no?
http://www.quadratec.com/products/16192_250.htm
Old Mar 26, 2011 | 09:30 AM
GON WHLN's Avatar
Found this for the Fly-by-wire JK system:
[.4x4rockshop.com/Scripts/prodView.asp?idproduct=13640"ww.4x4rockshop.com/Scripts/prodView.asp?idproduct=13640
Old Mar 26, 2011 | 09:42 AM
GON WHLN's Avatar
I already have a flashpaq, maybe I should just get used to carrying it with me and doing the idle up procedure then.
Old Mar 26, 2011 | 09:57 AM
My brother i'n law had one on his yj when he bought it, it looked like the guy that had it before took the clutch handle off of a dirtbike and mounted it to the shifter
Old Mar 26, 2011 | 10:27 AM
emoody007's Avatar
The Flashpaq doesn't idle in real time. You change the idle rpm's then hit enter and then it changes. I don't thing it will serve your purpose as a hand held throttle. However its a great feature if you need to idle up for winch use.
Old Mar 26, 2011 | 01:39 PM
sclan's Avatar
Default Additional discussion
Here was some additional discussion on the idea from a few years ago
https://www.jk-forum.com/forums/show...-Hand-Throttle
Old Mar 27, 2011 | 10:17 PM
[4x4rockshop.com/Scripts/prodView.asp?idproduct=13640
Good find!!!! I am looking for the exact same thing. Im finishing an install of a YORK OBA system and have been looking at ideas for idle control since the JK is fly-by-wire.
