Fitting 35's
Old Jun 21, 2011 | 05:05 PM
tljk2007's Avatar
Default I cut the pinch seam.
Originally Posted by JocKy
Best thing to do is toss on the tires and flex it some where. Just not on a trail run. This should show you what you need to do.
I have true 35's and a 2.5 coil and had to trim 1" off the rubi rock rail and I bent the pinch seam. (I was rubbing on speed bumps.) However, cutting the pinch seam is a better option as the paint chips and peals when you bend it. If you cut it (sawzall) you can then do a light sanding a little black paint to protect the body from rust.
I put the new tires on and set it down, the tire was about 1 1/2" from the tire so I went ahead and cut it off. I sanded, primed and put the black paint to it. It looks alot better without that tire snag on there anyway.
Old Jun 22, 2011 | 08:11 AM
orfanidisnikolaos's Avatar
i run BFGs ATs 315/70/17(34inch measured) with an 2inch OME lift (actual height gains was 2.5inch) and i dont rub in the pinch seam even at full flex. When at full flex though i rub at the fenders even i use bumpstops Thats why i am going to do an 1.25inch RC body lift. Go on with the 35s project it really worth it.
Old Jun 22, 2011 | 09:55 AM
mike-d's Avatar
I plan on running Durtrac's and I hear they are a small 35. So we will see how that goes.
Old Jun 22, 2011 | 11:02 AM
felix_434's Avatar
stupid question from the newbie. What's the pinch seam?
Old Jun 22, 2011 | 11:07 AM
TURTLECON's Avatar
That piece of metal just behind your front tire and in front of your rear tire where the side panels of the vehicle are welded (pinched) together.
Old Jun 22, 2011 | 11:12 AM
tljk2007's Avatar
Default pinch seam
Look at the rear tire toward the front of the jeep in the fender well. You will see a peice of metal that really looks out of place.(That is the pinch seam.) If you have big tires it gives you an uncomfortable feeling.
Old Jun 22, 2011 | 11:27 AM
felix_434's Avatar
nice thanks, i'm about to do a TF 2.5" coil lift with 35's. Yet another thing to look out for!
Old Jun 22, 2011 | 11:31 AM
speed2005's Avatar
Stop with the pinch seam trimming posts.
It is most likely NOT needed.
I have 35s with no lift and flexed it to check. It will NOT contact the pinch corners!
Now my 35s are on the small side (duratracks) so I recommend flexing your setup and checking but posting that triming pinch to fit 35s is requiered is simpley not accurate.
my .02
Old Jun 22, 2011 | 11:49 AM
speed2005's Avatar
Really? Would you feel comfortable driving down the road with this?? One good bump and that pinch seam runs up into the tire. 35" km2s measuring to 34"
Would I? Yes. I am currently running like that. No issues what's so ever. Tires travel up and down not front to back.
As I said, probably best for everyone to check with the setup they have.
I checked mine and could not get it to contact. I feel comfortable with it.
When I get a lift I will feel even more comfortable.
My .02 so take it or leave it. No hard feelings.
Old Jun 22, 2011 | 01:54 PM
tlhall2's Avatar
Put on a 1" body lift... Looks good with 2.5 lift and 35s anyway IMHO.
