Fix castor direction?
Old Dec 5, 2012 | 06:35 PM
CCTEX84's Avatar
Default Fix castor direction?
I have 285 with a 1 3/5 front coil spacer. My castor is reading 3.1 with castor not being terribly low what would be the best option to raise it. I don't wanna spend over 200 on lower adjustables. Cam bolt seem shady and lower Aev bracket is only for 2.5 inches or higher. Is there any other option or did I ansmwer my own question and pull the trigger on adjustables.
CCTEX84's Avatar
My bad I mean 1 3/4
Old Dec 6, 2012 | 01:50 AM
OH9JK's Avatar
JK-Forum Ambassador
1-3/4" spacer lift "shouldn't" require anything....however, adjustable arms would be the way to go. Stay away from cam bolts!
Project-JK.com - Jeep JK Wrangler Resource » Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Old Dec 6, 2012 | 02:39 AM
EzK's Avatar
EzK
If it doesn't drive poorly I'd say nothing needed. Go control arms if you do.
I put Rock Krawler front lowers on mine last weekend, huge improvement. (Don't attempt without a bench vise to tighten the jam nut. I don't feel good about how tight I got mine.)
Old Dec 6, 2012 | 05:33 AM
SiliconTi's Avatar
I'll yell this out for emphasis:
DO NOT USE CAM BOLTS!
I did and it was the dumbest thing I did to my Jeep. Go with new arms, or leave it if the ride and handling are OK.
