Fixing to install evo draglink flip.
Old Dec 10, 2013 | 07:30 AM
bombout800's Avatar
Default Fixing to install evo draglink flip.
Anyone have any pointers? Wish me luck
Old Dec 10, 2013 | 09:08 AM
DunnyBunny's Avatar
JK-Forum Ambassador
I would have went with the synergy. Not much more expensive but gives you new ends that are better and it's a beefier bar as opposed to your current stock draglink just from a right hand drive.
Old Dec 10, 2013 | 02:39 PM
bombout800's Avatar
Too late. I can always upgrade stuff later. So installed it and I think my axle center is off cause one of my sway bar link bolts hits the very lowest part of my upper coil bucket. So I guess tomorrow I'll be centering and checking my toe again.
Old Dec 10, 2013 | 03:50 PM
kjeeper10's Avatar
Vet Army
Yea, you are essentially returning the angle of the track bar back to stock. Some will reuse their stock track bar because the aftermarket can't go short enough.
Old Dec 10, 2013 | 03:52 PM
DunnyBunny's Avatar
JK-Forum Ambassador
Exactly what I was thinking.
Old Dec 10, 2013 | 08:52 PM
bombout800's Avatar
Well my aftermarket one is now to short. The axle is pulled to the drivers side too much. So I have to measure everything tomorrow and center it back up. I left a bolt out of the track bar bracket. Probably because the instructions were shit and stripped a cheap lug nut. But tomorrow is a new day. Definitely feels lighter on steering and less pull(bumpsteer). Suspension seems to be doing a little more work. I just have to straighten the axle as my sway bar link hits metal to metal on big bumps.
I also need to adjust sway bar down about an inch. I had to get to work and had to get the jeep back to the house before doing so. I was rushed and couldn't get it all done. So, I'll be spending tomorrow dialing things in. Big up was I got my steerin wheel straight after only adjusting the draglink twice!! Set cruise and took some sharp turns and no esp. That part went really well! Haha
