fixing rake on a stock 2011 with 33s
Old Mar 21, 2013 | 02:51 PM
RubiconEurope's Avatar
Default fixing rake on a stock 2011 with 33s
Hey guys, I have a 2011 2 door Rubicon with alloy usa 1.5" Spacers on wheels and 285/70/17 BF Goodrich All Terrain tires, Its completely stock other wise, And I wish to fix the rake it has even as slight as it is, Would Daystar 0.75" fix this or would it be too high?. I want a perfectly level stance, and not high because It'd make me feel like my tires are too small, So just a 0.75" Daystar spacer in front would be the fix or no? What else have you guys done? I want it to be less than an inch if possible.
Old Mar 21, 2013 | 04:28 PM
Kichu's Avatar
Are you sure you're not imagining the rake? I'm pretty sure there is no factory rake on the 2011 and onwards 2 doors. I know mine doesn't have a rake!
Old Mar 21, 2013 | 04:31 PM
swaite3's Avatar
Yes, I ran a .75 rear and 1.75 front and jeep was level so just a .75 front should be close
Old Mar 21, 2013 | 05:04 PM
Ryan0260's Avatar
Yes, 3/4" spacers should level it out.
Old Mar 22, 2013 | 01:23 AM
Kojack's Avatar
I would use the full teraflex lift. I am running it with 285 and my tires look great.
Old Mar 22, 2013 | 02:17 PM
Thanks for replies, I have a 2 door though, So, If I buy this kit:
Daystar KJ09138BK - Daystar 3/4" Comfort Ride Lift Kit in Black for 07-13 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
and only put front spacers, will it be level?.
Old Mar 23, 2013 | 02:52 AM
Kojack's Avatar
The teraflex works for 2 and 4 door. And after the kit is installed, your jeep will sit level.
