Flag Mount?
Old Jul 25, 2007 | 09:09 AM
BLKRuby's Avatar
Default Flag Mount?
Where and how are you guys mounting trail flag? I ahve to make some up tonight and wondering what you all are doing?
Old Jul 25, 2007 | 10:44 AM
chvynova's Avatar
I mounted mine between the spare and the gate, on the flat spot of the tire carrier to the right of the brake light.
Old Jul 25, 2007 | 11:56 AM
BLKRuby's Avatar
Pic maybe?
Old Jul 25, 2007 | 01:04 PM
dsp's Avatar
dsp
At Silver Lake, you have to put the flag on the front of the vehicle. We put ours on the front tow hook, we bough a bracket from one of the stores in town.
Oh, we had a blast
Old Jul 25, 2007 | 03:09 PM
BLKRuby's Avatar
Yeah, i made a little bracket that attatches to the metal bumper behind the plastics. Should be more than good enough for the weekend.
Old Jul 25, 2007 | 05:11 PM
Wings fan's Avatar
Went to Silver lake last week. I drilled a 3/4" hole in the plastic on the top of the front bumber and a smaller hole in the steel portion. I picked up a rubber plug for $.50 at the local hardware and it looks factory when the flag is not in. I had it done in 10 min. and had zero issues all last week. Climbed test hill 4 times.
Old Jul 25, 2007 | 05:51 PM
dsp's Avatar
dsp
Very good, I did not make it up test hill at all....first time there in my wifes JK.
Someone suggested that I should have turned the overdrive off. I will try again when we go back in Oct
Old Jul 25, 2007 | 06:00 PM
Wings fan's Avatar
It was hard to get the auto to shift when I wanted it to. Best results on test were 4 low overdrive off and 2/3 up let up slightly on gas and shift to 2nd and then matt it. This resulted in down shifting to 2nd and rpms to 5K range. If I didn't get 2nd gear I never made it. Good luck had a blast I'll try to post pics this weekend.
Old Jul 25, 2007 | 07:16 PM
BLKRuby's Avatar
What tires and air pressure were you running? 3.21 or 4.10?
Old Jul 25, 2007 | 08:14 PM
Wings fan's Avatar
Tires 285/70/17 BFG AT at 12psi one day and 9psi all around the next and 4:10's. The 12psi day the sand was a little more solid but I think I could have gone to 7 or 8 the side walls seem pretty stiff on the tires.
