Flag Mount
Old Jan 12, 2014 | 09:55 PM
iiM RuSHiN's Avatar
Default Flag Mount
Getting a 3'x5' Seahawks flag and I wanted to mount it on my rig, anyone have an idea of how to go about doing this?
Old Jan 12, 2014 | 09:59 PM
echoshotz's Avatar
I did mine with PVC and U bolts.
Old Jan 12, 2014 | 10:33 PM
RockieMtn's Avatar
Sorry, I only know how to mount Broncos flags...
Old Jan 12, 2014 | 10:41 PM
iiM RuSHiN's Avatar
Knew there would be a guy like you. Haha
Old Jan 12, 2014 | 11:56 PM
RockieMtn's Avatar
It had to be said
I've seen people around town with their doors off putting smaller flags in the door hinges. I know that doesn't exactly help with your problem, but it's an option. Also, zip ties work wonders!
Old Jan 13, 2014 | 01:07 PM
Fooddude's Avatar
Angle iron cut, drilled, painted and screwed to brake light using existing bolts.
Mount antenna with spring and attach flag.
FD
ID:	523392   Click image for larger version
ID:	523393   Click image for larger version
ID:	523394   Click image for larger version
ID:	523395   Click image for larger version
Old Jan 13, 2014 | 03:01 PM
Cjsmith4's Avatar
I've been looking for a way to mount a flag too but I don't have a spare tire carrier to mount it to. At this point I'd have to find a way to mount to the stock bumper.
Old Jan 13, 2014 | 03:19 PM
karls's Avatar
You could use the same concept posted just above you but run it between the tailgate and a couple of the bolts for the tire carrier (albeit removed).
Old Jan 13, 2014 | 03:42 PM
Dirt Racer 35's Avatar
I originally created a mount using the trailer hitch, unfortunately it doesn't get the pole high enough for the flag to fly with the top on. So I decided to make another mount for top on or off and gave the other one to a buddy with a truck... The new one mounts using the spare tire bolt holes. Unfortunately I don't have good pictures of the mount, but it's a piece of tubing with two tabs welded on for mounting then a bolt in the bottom to keep the pole from sliding down, and two bolts in the side to hold the pole from coming up.
ID:	523423   Click image for larger version
Old Jan 13, 2014 | 03:49 PM
kellyII's Avatar
X2 all a others are obsolete lol
