Flex and bump stop question
Old Dec 17, 2012 | 07:43 AM
theZombie's Avatar
Default Flex and bump stop question
I'm currently running my AEV 2.5" lift and just got my 35's put on. Now for my question. Theoretically, If I put flat fenders on, would I be able to remove the AEV bump stops and leave the factory bump stops and gain more up-travel? My curious mind is at work
Last time I was in the sand, I hit an unexpected jump and the front end hit the bumpstops.
Old Dec 17, 2012 | 08:23 AM
TheTerminator's Avatar
As long as you still have coil and shock travel left, then you should be fine.
Old Dec 17, 2012 | 09:09 AM
Jeeperz Creeperz's Avatar
Should be fine, when i put my lift on i didnt use the extended bumpstops. Test flex first to make sure though!
Not only do they keep from over compressing they also help to keep the spring from over flexing and popping out
Old Dec 17, 2012 | 11:10 AM
keithvegas's Avatar
The bump stops are there to prevent you from destroying your shocks. If you put on longer shocks or moved the stock shocks using brackets you will end up using your shock as a bump stop and smash it.
On taller lifts added track bar brackets, flipped drag links and other suspension parts will get smashed.
The only way to tell for sure is to take the springs out and see how far you can go before something bad happens. That said, it isn't going to help your situation much. If you want to jump your Jeep you want to look into air bump stops. Then look into gussets, sleeves and a truss or an aftermarket housing cause the axles aren't gonna take that abuse for long.
Old Dec 17, 2012 | 11:18 AM
theZombie's Avatar
That's what i was afraid of. I don't intend on jumping, it was just something that happened on a fishing trip.
Old Dec 17, 2012 | 06:39 PM
Smashboogie 4x4's Avatar
Former Vendor
That must have been one hell of a fishing trip.
Old Dec 17, 2012 | 07:29 PM
theZombie's Avatar
Haha yah. 60 Miles of strait coast to fish. The fun part is driving to perfect spot
Old Dec 18, 2012 | 02:36 AM
rtguy1's Avatar
this.. remove springs. cycle suspension. u will be able to determine exactly how much bump stop you need and install accordingly. this is the ONLY way to properly get as much "stuff" as your setup will allow without causing any damage/rubbing.
