Flex problem
Old Nov 11, 2013 | 07:18 PM
Flexer07's Avatar
Default Flex problem
I have the rock krawler 3.5 X factor and my rear track bar is bottoming out on my bump stop on passenger side has anyone else had this problem.
Old Nov 12, 2013 | 05:49 PM
Smashboogie 4x4's Avatar
Former Vendor
Can you post a picture so we can see what is happening?
Old Nov 12, 2013 | 05:57 PM
D_engel's Avatar
if the bumpstop extensions are anything like teraflex's, they extend forward from the axle to allow users to push their rear axle back and still retain a proper bumpstop pad. You may have them on backwards
Old Nov 12, 2013 | 06:38 PM
Stepsride's Avatar
Rotate the track bar back a little bit.
Old Nov 13, 2013 | 04:18 AM
Flexer07's Avatar
The track bar mounting location is hitting the bump stop bad. So rotating the track bar will not help. I do have teraflex bump stops that extend forward.
Old Nov 13, 2013 | 06:53 AM
ttechris's Avatar
Are your arms adjusted to the correct lenght? I installed a buddy of mines lift, and his trackbar bolt was coming in contact with the bumpstops. We were able to trim the bumpstops to clear(His stops were steel.)
I recently installed another guys 3.5 X-Factor kit on a 4dr, and didn't have that issue at all when arms were adjusted to RK specs.
Old Nov 13, 2013 | 06:59 AM
Mello03's Avatar
Is your pinion rotated? I had to trim my bump stop a bit and reverse the track bar bolt to fix mine.
Old Nov 13, 2013 | 07:16 AM
TheDirtman's Avatar
Yes, I have seen that exact problem with the rock krawler kit. Made a new track bar bracket for a couple of people to solve the problem.
Flexer07's Avatar
Originally Posted by ttechris
Are your arms adjusted to the correct lenght? I installed a buddy of mines lift, and his trackbar bolt was coming in contact with the bumpstops. We were able to trim the bumpstops to clear(His stops were steel.) I recently installed another guys 3.5 X-Factor kit on a 4dr, and didn't have that issue at all when arms were adjusted to RK specs.
when I installed the lift I used the measure man for the adjustable control arms. And it moved the axle back and rotated it. But seems if I didn't have bump stops at all the track bar bracket would still contact the bump stop pad on axle. I would post a picture but the iphone app is jacked up lol
Old Nov 13, 2013 | 07:07 PM
kjeeper10's Avatar
Vet Army
You try loosening both jam nuts and rotating the track bar away a little ?
I've also seen a few people double shear the frame side mount.
