Flexing with Teraflex leveling kit?
Old Oct 22, 2013 | 02:57 PM
jonb1032's Avatar
Default Flexing with Teraflex leveling kit?
Just installed the Teraflex leveling kit (spacers), (2013 Rubicon) so far love it. This weekend going to try it out offroad. It did come with longer front sway bar links. But the brake lines and shocks remain stock. Has anyone any experience when flexing this kit. Will the brake lines get too tight or the springs fall out? That would ruin the day.
Old Oct 22, 2013 | 03:40 PM
kh202's Avatar
No problems with mine. I have tweeked an abs sensor, but I did that once stock as well. But yours should have come with rear brackets. And if you didn't get the kit that came with shock extensions, you should get some for sure so you don't over extend the shocks
Old Oct 22, 2013 | 03:43 PM
bsmarble's Avatar
I have the same set up, I love it also. Brake lines should be fine. without shock extensions and brake lines you will just loose a little downward travel. Best thing is road manners are still like stock. Good luck.
Old Oct 23, 2013 | 04:38 PM
Dbmoorejr's Avatar
It seems crazy but get it aligned. I had wear issues after putting mine on.
Sent using smoke signals
