flighty steering
Longer lower control arms. Either adjustable or fixed length designed for your lift amount will work. I had the same problem and ordered a set of "j-spec fixed length" front lowers from northridge4x4 and it's great now.
Caster!! The caster must be raised with the lift! I added adjustable lowers and it took the problem away. I didn’t have death wobble but bump steer and wondering. It took care of it and back to a stock feeling. I had a four inch lift put in, it raised the front 5.5 inches. I had horrible bump steer and it was very flighty. I put the caster up to 6.0 degrees and that took care of the problem but then I realized my pinion was pointing down so I ordered a Pro Rock 44 unlimited and that took care of the pinion angle!!
Here is a link to a good place to start to look at your issues after your lift.
Project-JK.com - Jeep JK Wrangler Resource » Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Hope this helps you out. Good luck in your fix.
Doc Highway
Doc Highway
