"Flighty" steering.
Wow,
1 degree is pretty severe! Must be wandering all over the place.
Be sure you set the angle finder on the ground first or ensure you're on level ground, otherwise it will miss lead you. But if you've raised things, it's gonna go down from factory setting (4.2 I believe).
BTW I have mine in the 7 - 8 range.
Blue Mesa
Blue Mesa
Wow,
Blue Mesa
Blue Mesa
It is great now. Very comfortable to drive. One hand on the wheel. No longer the feeling of being on ice etc...
Hope that helps.
Blue Mesa
it was pretty windy up here today, and it was a bit of a white knuckle drive on the highway. i thought it was because of my undersized steering stabilizer (i got sick of paying 70-80 bux a pop for new ones and stole one from a TJ axle, so that probably doesnt help) but i guess should check my caster... i figured it would be out, but after seeing 1 degree of caster, it just jumped to the top of my to do list.
thanks for bringing this to my attention
2 people and a tape measure before and after a lift can detect the difference quite readily. Measure the distance from the midpoint on the outer edge on the back of the front tires and then the midpoint on the outer edge of the front tires and you can see real quick what happened. Also measure the wheelbase before and after.
A good example of the effects of even a very small increment of change in caster can be found in motocross bikes. In the mid to late 90's Honda and Suzuki had quite a steep rake and as a result would turn on a dime but their high speed stabilty was awful resulting in whats called "head shake" which is basically a terrible oscillation that you felt transmitted through the handlebars and caused you to let off the power because on the intense shaking felt in your arms and shoulders. On the other hand, Kawasaki and Yamaha increased the rake of their forks which made them handle like a dream at high speed over rough terrain but when you came into a corner it was quite difficult to turn. It doesn't matter anymore as a little stabilizer has been added to tame this problem. Anyway, so much for Suspension 101...
Alright, so when I install my new adjustable CAs do I have to disconnect BOTH uppers and lowers from the front axle to get the axle to proper caster? Or can I get enough movement by installing uppers while having the lowers in-tact and vice versa? Does that make any sense? HAHA
Edit:
Or were you asking if you can get enough caster adj by only replacing the lowers or uppers? Im not 100% sure, but I think you can. The alxe just wont be as centered under the springs.
I would check the length on your lowers compared to the stock ones. You might be ok with just uppers. Or at least closer to an acceptable caster until you decide to replace lowers too. I think I set the lowers to 3/8 longer then stock and the uppers an 1/8" longer
I ended up with 5 degrees, It handles ok, but I think it will be even better at 6-7. When I have another free day (preferably a warm one), I plan on readjusting them.
