flighty steering problem, need advise!!
Old Feb 11, 2013 | 12:15 PM
Default flighty steering problem, need advise!!
My Jeep feels flighty at highway speeds and tends to wander a lot and I need some advise.
Here's my set up;
2007 2 dr Rubicon.
3.25 RC lift
35'' MTR/K on 15'' rims
so far this is what I did and/or installed to try to resolve this issue;
new upper/lower ball joints
new chromoly tie rod and tie rod ends
new JKS adj. track back, rear and front
new pitman arm ball joint
new steering stabilizer ( old one was leaking)
tire rotation (x2)
tire balancing (x2)
alignment (x2)
I know that getting adjustable LCA's would correct my caster and that could be one of the problem but I drove 5000 miles to Utah and back last April with the same set up and had zero problem.
The only other problem that I could think of is my electronic sway bar had stopped working long time ago and maybe it disengaged itself and now I'm driving disconnect. How can I confirm if it's connected or not ? Could that cause flighty steering?
And lastly do you think that tightening the steering box would help?
thanks!
Old Feb 11, 2013 | 12:20 PM
JeepnDude's Avatar
Why are you trying everything under the sun except LCAs, when even you acknowledged that LCAs are likely the fix you need?
Old Feb 11, 2013 | 12:21 PM
txjeeplover's Avatar
By chance, did you install Synergy or Alloy ball joints and did the flighty steering develop after the installation of either of those brands?
Old Feb 11, 2013 | 12:22 PM
JeepnDude's Avatar
Oh, and as for determining whether your swaybar is disconnected, just bend down and take a look.
Old Feb 11, 2013 | 12:23 PM
Shell's Avatar
What he said
Old Feb 11, 2013 | 12:52 PM
Ryan0260's Avatar
Before anything, how much air is in the tires? More than likely if that doesn't help, adjustable front lca's will. Also, did that kit come with a drop pitman arm?
Old Feb 11, 2013 | 12:58 PM
the parts that I changed were due anyway, either bent or loose. I'm just going by elimination here. Why would my caster be out of whack if it was ok before, it's not like I installed a new lift and that problem just occurred right after. I know that getting LCA's might fix it or not.... just trying to save money here.
Old Feb 11, 2013 | 01:00 PM
Synergy ball joint but the problem develop before that.
I run 28-30 psi
Old Feb 11, 2013 | 01:01 PM
E-swaybar.....
