FM Antena for the jk?
Old May 11, 2007 | 10:08 AM
mickfluff's Avatar
Default FM Antena for the jk?
My radio gets constant background static on most local FM stations, is there a direct replacement higher frequency (not sure that is even phrased correctly) antenna out there that's a fairly easy basic swap? Thanks
Old May 11, 2007 | 01:06 PM
John L's Avatar
You shouldn't be getting static on local stations, you might check and see if the antenna connector is fully seated in the back of the radio....
