Fog lights and driving lights
I've searched but I can't find an answer to my question. For you guys with fog and driving lights, where did you install the switches ? I've seen the pics of the single switches installed to the left of the steering wheel and the daystar panel but I don't really need four switches. Any suggestions? Sorry if this has been asked before.
I put mine same place. Before you cut anything, check the position while you're sitting in your normal driving position -- the blinker stalk blocks my view of the switch unless I move my head slightly. Otherwise, it's a good, unused spot. Sorry, no pics
I was in the same situation as you a few weeks ago. I have the daystar Switch Panel and at the moment I'm only using the one spot. But now I can add a few more switches with having to drill in my dash. Just have to cut out a spot on the panel each time.
If you don't have the power package, you can mount switches vertically in between the two a/c vents on the dash console. I have not done it yet, but that's where my switches are going. My driving lights and fog lights just came in from RallyLights, so I'm hoping to have them installed within a month. I'm still missing three things, a-pillar brackets and the cirkit boss from Painless Wiring, and some better looking switches. I found a website several weeks ago that had smaller switches (like the one that comes with the Hella 500's) with just about any symbol you could want on a switch; but, I can't remember what it is now.
