Ford conversion in jk
Old Nov 6, 2014 | 05:21 AM
  #31
Tooadvanced's Avatar
Originally Posted by rws
I know it sounds crazy low, but there's a chart here somewhere that shows tire size, gear ratio, and rpm turning for the jk, and with the 6:00 you're turning up 2400rpm at 70mph, which I was very surprised at.
Your comparing an out dated 4 speed auto to a modern 6 speed auto. Like us newer jks with the 5 speed auto don't have to gear near as low as the 4 speed did. 35's with the 4 speed need 5.13 ish gears where as the 5 speeds needs 4.10-4.56 with 4.88 and up being more towards the offroad only group
Old Nov 6, 2014 | 05:37 AM
  #32
JSS's Avatar
JSS
Former Vendor
We are the only shop that can do LS/Hemi swaps, it takes a lot of time to build a kit and test it. I think the VVT Truck Hemi is the best Hemi ever in a JK, the thing about the Hemi is it is all Mopar and easy to work on. So the Jeep Dealer can work on it.
Now the Chevrolet LS is a great engine and the 6L80 is a better trans, but it is a little more work to install it an now you would need some one that knows the GM side to work on the engine/trans and some that knows the Jeep side to work on the Jeep. It also looks like every time you put a LS in anything it needs to be tuned. I like my 6.2L/6L80 in my Jeep, but i also like the VVT Truck Hemi so it is hard, now if some one does a Ford 3.5 ecoboost it would take awhile to get the bugs worked out, but it would be a get engine in a Jeep but i would rather put the time into a Diesel.
The thing we are working on now is the LS in a JK, because we have the Hemi in a JK working really good! We have about 15 LS/JKs running around and they are doing great.
Old Nov 6, 2014 | 06:23 AM
  #33
Chadam's Avatar
A lot of you guys are acting like a raptor is fast. Don't get me wrong it's a sick truck, probably my favorite but it's the same if not slower than a stock 3.6 jk in the quarter mile. I only wish I had the money to do any of the motor swaps you guys are talking about. Might have to settle for a supercharger
Old Nov 6, 2014 | 06:37 AM
  #34
SoK66's Avatar
Interesting thread. My daily driver is a '13 5.0L F150, was thinking the other day how sweet that powertrain might be in a JK.
Old Nov 6, 2014 | 06:56 AM
  #35
jksteve2013's Avatar
Originally Posted by JSS
We are the only shop that can do LS/Hemi swaps, it takes a lot of time to build a kit and test it. .
the only shop eh.
so what about the 100 or so others who do it? you must build all of AEV trucks...
Old Nov 6, 2014 | 07:52 AM
  #36
rws's Avatar
rws
I hear what you're saying, but what I was doing was using the chart to compare the tire size and gearing it took the stock jk drivetrain to get in its power band for a specific size tire. Now if the 6l80 has a similar overdrive ratio (which it probably doesn't) that chart should be helpful in showing you where the LS rpm's should land with the same tire size and gearing.. It's rough estimate, but was the best I could come up with as there isn't many LS Jeeps on 40's out there.. So looking at the gear chart, and I'm looking at the 480hp LS3 is pushing 400ft/lbs @ 2500rpm which is where I would like my JK cruising at 70-75.. So taking that, you can figure out the formula on the chart I posted, substitute the jk's OD ratio with the 6l80's OD ratio and come up with an fairly accurate chart.. But as Robbie already said, WOL is running at 70mph @2300rpm with 5:38.. So with that info, I take look at all the LS3's, or any motor really, and see which one has the best curve for that rpm, or gear higher and go from there..
Old Nov 6, 2014 | 03:44 PM
  #37
Originally Posted by jksteve2013
the only shop eh.
He means the only shop doing ls and hemi swaps. There are lots that do one or the other but not both
Old Jun 24, 2020 | 07:02 PM
  #38
5.0 JKU's Avatar
Have any companies made a kit for a old school 302?
I am going to do away with the 3.6l and am going to run a 302 hopefully on the stock NSG370 6 speed.
Old Jun 28, 2020 | 07:07 PM
  #39
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
5.0 JKU - you will tear the shit out of that gearbox with virtually any V8 behind it. It can hardly stand the stock V6 "power". That is why repowering costs so much because it is like replacing the drivetrain. And that 302 will eat fuel unless you use the last FI 302 you can find. Lots of work for less return power wise. 5.3 Chev is the best engine at this cubic inch capacity.
Old Jul 1, 2020 | 03:26 AM
  #40
Mike H.'s Avatar
I'm a real sucker for the Ford Windsor 302... but I'd not put one in the 4500lb+ Jeep... at least not a stock block version.
Now, a Dart block, running 3.4stroke x 4.125bore (363cubes) with some ~200-220cc heads... that could be a real nice truck motor... albeit ~100lbs heavier than the 5.3, but making more power... and costing a boat ton more to do.
Wonder why no one was discussing the 6.4hemi... I mean, this thread is 6 years old, but hadn't the 6.4hemi already been in production at that point?
