forgot to remove the factory washers before wheel spacer install !
Hi,
I forgot to remove the factory washers as described in step 2 of this write up before installing the spacers !
:http://project-jk.com/jeep-jk-write-...ation-write-up
what should I do ?
what should I do ?
I wonder why spidertrax did not mention this in their instructions !
However, there was an inner space on the back of the spacer which allowed the spacer to sit flush, I wonder if that was intentional ?
because not all vehicles have them. the JK does and, even though you "might" be okay, i don't know if i would chance it. the assembly washers are not a precise machined part or even installed like one and can sit off to one side or the other, there is a chance it can get under the spacer. maybe it's not a big deal but again, why risk it? while i have only seen a few wheel spacer failures over the years, all of them have been the result of install error.
I installed mine and left them on as well. After I realised it though I just became way too paranoid and removed them. I don't think it would be an issue as the spider trax spacers had a good sized hollow around it anyway but like stated earlier why chance it.
Originally Posted by RedJK2
It is actually mentioned in step 1:
"Remove drum/rotor retainer clip(s) if present."
