FOX 2.0 Steering Stabilizer install, HELP please.
So, I thought this was going to be an easy install. Just replacing my 11 year old factory steering stabilizer with a FOX 2.0.
As you can see from the first photo, the fox cylinder diameter is quite a bit larger than factory. As a result I could not position the Fox in the same orientation as the factory because of a bracket (Passenger Side) that was in the way. I flipped the steering stabilizer 180° and it did install just fine. However when I tried to turn lock to lock I could not turn to the right without the Fox cylinder hitting up against that bracket. This is shown in the second photo. Is there some aftermarket bracket that I need to purchase in order to install this larger steering stabilizer? TIA. https://cimg0.ibsrv.net/gimg/www.jk-...78288ee60f.jpg https://cimg1.ibsrv.net/gimg/www.jk-...a023706d84.jpg |
Looks like I found my solution. My local 4 Wheel Parts store is giving me a freebe Rubicon relocation bracket, including hardware.
https://cimg3.ibsrv.net/gimg/www.jk-...1e61b79637.jpg |
I used the Teraflex Stabilizer Relocation kit to install a Fox Stabilizer, looked good. But ditched the Fox Stabilizer because it caused the Jeep to pull to the left. But it looked good. |
Originally Posted by larock1971
(Post 4338483)
Originally Posted by spartacus_33
(Post 4338488)
Did you try to adjust it?
Because of the gas charge, they inherently push your tierod to the left. |
Originally Posted by jdinny
(Post 4338493)
You can't adjust the left pull out of a gas charged stabilizer.
(Post 4338495)
... then why would they continue to make and sell them?
(Post 4338488)
(Post 4338500)
The Fox Shocks I have installed are great, but the Steering Stabilizer just didn't work for me. The charge was dropped in the SS I installed, but it still pulled. I understand Fox addressed the pull with their ATS SS, but it's a bit pricey. I ended up bolting up a Rancho SS and have been happy, it just doesn't look as cool. |
(Post 4338495)
Originally Posted by Ghost JK
(Post 4338497)
Because people buy them for the cool factor. A proper steering setup doesn't really need a stabilizer, and the factory one is fine until you bash it on a rock or it starts leaking.
because for 150 bucks, people keep buying them, so they will continue to make and sell them. |
