FOX 2.0 Steering Stabilizer install, HELP please.
Old Mar 20, 2019 | 02:06 PM
spartacus_33's Avatar
Default FOX 2.0 Steering Stabilizer install, HELP please.
So, I thought this was going to be an easy install. Just replacing my 11 year old factory steering stabilizer with a FOX 2.0.
As you can see from the first photo, the fox cylinder diameter is quite a bit larger than factory.
As a result I could not position the Fox in the same orientation as the factory because of a bracket (Passenger Side) that was in the way. I flipped the steering stabilizer 180° and it did install just fine. However when I tried to turn lock to lock I could not turn to the right without the Fox cylinder hitting up against that bracket. This is shown in the second photo.
Is there some aftermarket bracket that I need to purchase in order to install this larger steering stabilizer? TIA.
Old Mar 20, 2019 | 05:09 PM
Looks like I found my solution. My local 4 Wheel Parts store is giving me a freebe Rubicon relocation bracket, including hardware.
Old Mar 20, 2019 | 06:15 PM
larock1971's Avatar
I used the Teraflex Stabilizer Relocation kit to install a Fox Stabilizer, looked good. But ditched the Fox Stabilizer because it caused the Jeep to pull to the left. But it looked good.
Old Mar 20, 2019 | 08:49 PM
Did you try to adjust it?
Old Mar 21, 2019 | 05:56 AM
jdinny's Avatar
Loved
Community Favorite
From: up in the woods, on the back side of a mountain
You can't adjust the left pull out of a gas charged stabilizer.
Because of the gas charge, they inherently push your tierod to the left.
Old Mar 21, 2019 | 06:10 AM
​​​​​​... then why would they continue to make and sell them?
Old Mar 21, 2019 | 06:18 AM
Ghost JK's Avatar
5 Year Member
Because people buy them for the cool factor. A proper steering setup doesn't really need a stabilizer, and the factory one is fine until you bash it on a rock or it starts leaking.
Old Mar 21, 2019 | 06:25 AM
larock1971's Avatar
The Fox Shocks I have installed are great, but the Steering Stabilizer just didn't work for me. The charge was dropped in the SS I installed, but it still pulled. I understand Fox addressed the pull with their ATS SS, but it's a bit pricey. I ended up bolting up a Rancho SS and have been happy, it just doesn't look as cool.
Old Mar 21, 2019 | 06:30 AM
Why doesn't the Rancho SS pull?
Old Mar 21, 2019 | 06:31 AM
jdinny's Avatar
Loved
Community Favorite
This is why ^^^^
because for 150 bucks, people keep buying them, so they will continue to make and sell them.
