Frame Side Track Bar Mount
So a few months back I developed a slight wobble in the steering after hitting a bump, yep you guessed it the dreaded DW. Well after doing some investigation I found my frame side track bar mount was just a little elongated. So I asked myself, "Self what are you going to do now?" I proceeded to answer and say well lets put some weld washers on and get a 9/16 grade 8 bolt, top lock nut and some weld washers and then go to town. So ordered them from Allen's Fasteners and they arrived about 5 days later. After they arrived I put Canvas in the shop and began to fix his wobble. Here are the parts I used and how I did it.
Weld Washers
9/16 CHROMOLY WELD WASHER
Grade 8 9/16 x12 bolt (measure before ordering)
9/16-12 GRADE 8 BOLT
Grade C Top Lock Nut
GRADE C LOCK NUT
Video of how I did it
If you have questions please feel free to shoot me a PM
Weld Washers
GRADE C LOCK NUT
Is that a quick tack that you cut off of the nut to keep it from moving? Seems like that step could keep a lot of folks from having issues once they set the torque correctly....although it may destroy the nut if they need to remove it in the future.
I was wondering why so much trouble removing the bolt and nut? I guess if I were worried about it I would just use a dab of red locktite on that particular fastener vs welding it.
The hole was so sloppy that event tightening would not keep it in place. I tacked the nut and bolt to keep it from wobbling. I was not worried about keeping the nut or bolt since I have a replacement on hand.
I had globbed a couple of tacks on there and they were well lets say in not the easiest place to get at. Tightening the nut would not have kept it in place since the hole was so sloppy. The tacks kept the track where it needed.
The ole wallowed out frame side hole.....smh. That factory bracketry sux so bad. Glad you spotted the issue, chose your method of remedy, and knocked it out. That spot seems to often be left alone until people have an issue with it........cept, DW isn't one of those things that's "fun" to experience even once!
That was your only issue? You didn't have a wobble before that then wallowed out the hole? It was just gradual wear and tear over the years?
