Freedom panel clips
Ok so I found part # but they are expensive SOBs so.... Guide to fix
1. If you close and outer clip tangles and does not lock, look at pin, should be going through 4 holes, likely is bent from pressure on it
2. Take out pin and straighten it
3. take panel off to help get better angle to put pin back in.
4. Get pin through 3 holes and not have it line up with 4th
5. Swear loudly
6. Use a nail, needle nose plyers and pry into fourth hole, part for one at dealorship is 50 bucks or you can order through chrysler for 30
5. Swear loudly
