Front axel/locker?!?
Old Jun 27, 2016 | 12:27 PM
mudrider's Avatar
Default Front axel/locker?!?
My 2011 Rubicon JK you makes a loud metal clicking noise when it's engaged in the four-wheel-drive on the front left it's very loud and it times it doesn't make a noise. Simultaneously my front walk or light blinks continually as if it's not engaged. Into will drive mode you could hear a constant noise as if the brake sensor was beginning to wear but that's not what it is coming from the same front left tire area. Any suggestions on what it might be. I'm afraid it's axle teeth broken off or something like that I DK though
Old Jun 27, 2016 | 02:15 PM
jtphoto JK's Avatar
It could be the axle UJoint at the front hub.
Old Jun 27, 2016 | 03:13 PM
mudrider's Avatar
lol that sounds too easy and cheap my mind says it supposed to be expensive and complicated. But I will def ask someone to listen to it, if it sounds ujointy to them bc idk and I should. Thank you
