Front Axle Options
#31
Former Vendor
Yes they do! It's an awesome feature. It is more than just adjusting caster and camber. People don't realize that when they put on larger tires, things such as scrub radius change. The adjustment sleeves provide the ability to adjust that. We'll leave akerman angle for another day.
#32
#33
There's several versions of this that Ford used. For example, the 1-ton my wife drives (97) uses a sleeve that has a castle type top to it with the hole that the ball joint goes through off center. The C of the axle has corresponding castle part so the sleeve fits into that like a gear inside a gear. You can rotate that sleeve one tooth at a time and this changes the caster and camber at the same time. You can order the sleeves with the hole offset different amounts. This link shows a bunch of different types that Ford has used.
https://www.google.com/search?q=ford...HZ1GAycQsAQIHg
#34
There's several versions of this that Ford used. For example, the 1-ton my wife drives (97) uses a sleeve that has a castle type top to it with the hole that the ball joint goes through off center. The C of the axle has corresponding castle part so the sleeve fits into that like a gear inside a gear. You can rotate that sleeve one tooth at a time and this changes the caster and camber at the same time. You can order the sleeves with the hole offset different amounts. This link shows a bunch of different types that Ford has used. https://www.google.com/search?q=ford...HZ1GAycQsAQIHg
On a related note, did anybody see the episode of Car Fix Where they did A D60/Sterling combo on a JK? Looks like they used the Artec kit but no mention.
#35
Yep, looked to be an Artec kit. The trick with the Sterling in a Jk is that it runs into the fuel tank. Fusion4x4 sent me an email saying they think they have a solution for it. I'm hoping so as they are the top of my list for axle upgrade.
#36
Former Vendor
We should know within a couple weeks. Another option would be to use our new Super 9 rear axle. Light, lots of ground clearance, and a nice fit into the JK. 3rd members are cool as anyone with some basic hand tools can swap one out. You can upgrade any time in the future and 3rd's can be bought and sold for good values, unlike a ring and pinion that are about worthless when used. So, you can save up some coin and swap to a 10" Gearworks third in the future. Not that it is needed, but they are very cool.
#37
#38
#39
Former Vendor
We can use Spider 9 housings. We use larger unit bearings and ones that work with JK electronics. The ends are massive D60 ends on the front (or Reid Super King Pin). Rear is a unit bearing floater, like you see on most KOH rigs.
#40
What are your thoughts specifically on the reasons I may be hesitant on going with a Fusion4x4 front axle swap instead of something like the dynatrac PR44 or other comparable manu. product i.e. Teraflex that was specifically made for the JKs? It's just that the other options (dynatrac, teraflex) seem to have more readily available support (manu. customer support, forums, etc.) than going with an axle that has been modified and only one "manu." to go through.
However, I guess if it retains ford components (gears, locker, tie rod, drag link, ball joints, etc.) and the connections from the frame to the jeep and drive shaft are that of a JK, then it shouldn't be a problem.
I am just trying to get a better fell for their (Fusion4x4) axle.
