Front axle shift
Old May 12, 2008 | 03:26 PM
xldme's Avatar
Default Front axle shift
Ok everyone, I've installed a 2.5" TF BB and 3/4" leveling spacer and noticed that my front axle has shifted about 1/2"to the passenger side. Is this enough shift to warrant purchasing an adjustable front traction bar?
Old May 12, 2008 | 03:36 PM
YankeeJim's Avatar
If you look at the front of your jeep with tire's straight you should see some shift.
Also it could put more wear on front drive.
I was off by 3/8 and put an adjustable track and it trued things up.
Old May 12, 2008 | 03:37 PM
bOLsAK=3's Avatar
1/2" to the passenger side?
Should be driver side...
An adjustable track bar is usually 1/2" longer than stock at it's shortest, so that would make it 1" to the passenger side if what you're saying is true.
Old May 12, 2008 | 05:39 PM
xldme's Avatar
The passenger side seems to stick out more.
