front bumpe for 37s
Old Feb 19, 2014 | 07:35 AM
pjmjk's Avatar
Default front bumpe for 37s
so ive been collecting up parts soon as the weather breaks im planning on taking a weekend and rigging up my 2010 jk 4 door sahara 6speed
im planning on doing flat fenders not heart set on which yet but grabbed teraflex 2.5inch lift with bilsteins already Tera Flex JK 4-door 2.5 inch Lift Kit, W/Shocks (1251000)
and im looking into bumpers now my current concern is trying to figure out what will fit functionally with 37 inch tires with the 2.5 lift as i want a full width bumper because i like the looks and cops around here will actually pull over stubbys. im thinkin about running toyo MT 37s anyone got suggestions for a good full width front bumper that would mix will with these pieces. ive been looking at a ton but havent really heartset on any option yet
Old Feb 19, 2014 | 07:51 AM
jeeperjkjeeper's Avatar
you will have interference issues with a full size bumper , 2.5" of lift and 37's. Let alone you will need flat fenders to run 37's on 2.5" of lift at a minimum and they won't look right with a full bumper imo.
Old Feb 19, 2014 | 08:13 AM
mattgt5's Avatar
Mid widths rub too. I had to change from my mid LOD to a stubby with my 37"
sent from my work leash
Old Feb 19, 2014 | 08:19 AM
JcrOffroad's Avatar
Sponsoring Manufacturer
You will need more like 4" to run 37's with stock flares. If you do go that high, then you can look at full width options.
Our Vanguard is high clearance and designed for little impact on tire size:
http://www.jcroffroad.com/product/JKVF.html
Our Crusader midwidth is slightly narrower then most, which would work in a 2" lift and 37" tire combination:
http://www.jcroffroad.com/product/JKCF.html
~Brian
Old Feb 19, 2014 | 10:15 AM
Invest2m4's Avatar
Check out the LoD Crawler. That's the route I ultimately went. Technically a stubby, but the top side extends out to a mid width. I have 37s on a 2.5" (netted 3") lift. Not even close to rubbing the bumper. It's fairly light as well and has a recessed winch opening.
Not a ton of pictures online, but in person it's pretty sweet.
Old Feb 19, 2014 | 04:37 PM
pjmjk's Avatar
well i know i need flat flares im def doing flats just havent picked a specific pair yet not that it matters much. damn thats what i was worried about with fulls rubbing on 37s i really dont want a stubby though the LOD is a possibility it at least gives a semi wider look
Old Feb 19, 2014 | 05:14 PM
Invest2m4's Avatar
In my opinion, if you're running flat fenders, anything much more than a stubby doesn't look good.
As a side note, I don't own anything Jcr, but I wouldn't hesitate to buy their product. The auto industry was born in MI and Jcr is bringing it back!
Shameless plug for Michigan based companies
Old Feb 19, 2014 | 05:16 PM
pjmjk's Avatar
also im not really worried about flex as its my daily driver and almost likely never to leave the curb but as i keep looking the stubby is starting to grow on me now to decide between bull bar or stinger
Old Feb 19, 2014 | 05:26 PM
mattgt5's Avatar
Here is the dagger stubby stinger from jcr.
Old Feb 19, 2014 | 05:30 PM
jaker t5's Avatar
3" lift and 37s no rubbing on my rampage recovery bumper
