Front bumper modification help!
Old Jul 19, 2014 | 12:47 PM
taylorfain2009's Avatar
Default Front bumper modification help!
Ok metal fab guys. I need to cut 4 openings on this bumper to fit 4 "fog" lights or flush mount leds whatever you want to call them. I want one at the end cap and one where the existing fog light holes are. On each side obviously. So how would I go about doing this? Metal fab is not a strength of mine
ID:	566270   Click image for larger version
ID:	566271   Click image for larger version
Old Jul 19, 2014 | 02:34 PM
Baddkarmaracing's Avatar
im not sure if it would work in your situation but i used a die grinder when i cut the holes for flush mounts in my raptor bumpers
Old Jul 20, 2014 | 07:49 PM
I used a jigsaw with metal blade and they worked out great! However no one commented in this which is kinda lame:/ anyways here is the finished product!
ID:	566584   Click image for larger version
ID:	566585   Click image for larger version
ID:	566586   Click image for larger version
ID:	566587   Click image for larger version
Old Jul 20, 2014 | 07:53 PM
Marshall31's Avatar
Nice job!
Old Jul 20, 2014 | 08:54 PM
Mountain Man Tim's Avatar
if I were to attempt this, ild measure out my mount points evenly, mark, drill the corners, then either use a dremel with a metal eater head, or a jig saw with metal blades to run the edges of the box holes. mind you youll want to use a clamped on straight edge so you cant wander outside of your marked cutting area, because frankly **** happens if you dont, and bumpers cost money.
Old Jul 20, 2014 | 08:55 PM
looks good
Old Jul 20, 2014 | 08:58 PM
NiteFighter's Avatar
Hey are you on the FRF?
Old Jul 21, 2014 | 05:37 AM
Yep but I sold the raptor :/ I miss it but I wanted out of the payment and fuel expenses so now I'm in this jeep.
Old Jul 21, 2014 | 08:53 AM
I did the same thing. I do miss the Raptor, but not the expenses!
Old Jul 21, 2014 | 09:06 AM
Chattinfarms's Avatar
Drill holes on the four corners and then use a jigsaw is usually how I do it
