Front Bumper Problem
Old Jan 28, 2013 | 01:10 AM
taccop318's Avatar
Default Front Bumper Problem
So I have ran into a little bit of a snag while researching front bumpers for my 2012 JKUS. I was looking at the Smittybilt SRC bumper w/ grille guard. While reading about it at Smittybiltdepot.com, I found out that it is not compatible with the 2012 because of the placement of the vacuum pump. I then looked at the XRC M.O.D. bumper and saw there was no issue with it. Is that a problem I am going to run into when I install any bumper or is it just the SRC?
Old Jan 28, 2013 | 01:11 AM
zombie4x4's Avatar
It depends on what the bumpers has behind it really but you can just get a vacuum pump relocation kit and then get any bumper you want
Old Jan 28, 2013 | 02:04 AM
16 Unlimited Ways's Avatar
I installed the Smitty XRC front and no problems...I no there is relocations kits
available for this situation...Actually is better to relocate i think...
Old Jan 28, 2013 | 05:10 AM
Jersey_Devil's Avatar
The relocation kits are fairly cheap too
Old Jan 28, 2013 | 07:58 AM
kfxbryan's Avatar
I have a new smittybilt relocation bracket for sale in the bumper section for $20 bucks shipped if you need one. I did not need it with my bumper setup.
Thanks,
Bryan
Old Jan 28, 2013 | 01:25 PM
taccop318's Avatar
Thank you for the replies. I just got off the phone with a Smittybilt rep who told me the bumper had been re-fabricated to compensate for the vacuum pump. The relocation bracket is no longer needed for the SRC Bumper. Once again thank you for the quick responses.
Old Jan 28, 2013 | 02:49 PM
Gman*2007's Avatar
I think if your planning on running a winch it probably needs relocated because the winch bolts between the frame.
Old Feb 28, 2013 | 06:26 AM
TristanWomack's Avatar
My dad is really opposed to cutting off the bracket that the pump is located on originally. Can I installs my RR XHD stubby without cutting off the old bracket?
