Front Coast 1310 DS install
I am getting ready to install my front DS tomorrow. I have everything I need per the write-up. However, my understanding is that I do not need a slip yoke eliminator kit. I am just confirming this is correct.
Not that I am aware of... I had to get a thin wall deep socket to install the output of the transfer case and if your front wheels are off the ground you will need someone to step on the brakes with engine on (for power) to torque down the output of the front axle (my jeep was on a lift when we put my ds on)
That is correct. The JK's moved the "slip yoke" to the driveshaft instead of having it in the transmission so you don't need to install an eliminator kit at the transmission.
